Salta al contenuto principale
Lenovo IdeaPad 300-17ISK Optical Drive Replacement
Cosa ti serve
  1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Keyboard: passo 1, immagine 1 di 1
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: passo 2, immagine 1 di 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: passo 2, immagine 2 di 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: passo 2, immagine 3 di 3
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: passo 3, immagine 2 di 2
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
  4. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Optical Drive: passo 4, immagine 1 di 1
    • Remove the 6mm Phillips #1 screw that sits in the center of the front plate below the keyboard. This screw sits between two adjacent tabbed holes.
  5. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: passo 5, immagine 1 di 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: passo 5, immagine 2 di 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: passo 5, immagine 3 di 3
    • Insert the opening tool's head into one of the tabbed holes.
    • With the opening tool's head inserted under a tab, push to the right. The optical drive should slide out easily.
Conclusione
Ammar Dodin
Membro da: 01/19/17
1.057 Reputazione
6 Guide realizzate
UC Davis, Team 1-3, Rodger Winter 2017 Membro di UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 39
Tutti i Tempi: 5,286
