Salta al contenuto principale
Lenovo IdeaPad 300-17ISK Keyboard Replacement
Cosa ti serve
  1. Lenovo IdeaPad 300-17ISK Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 2, immagine 1 di 3 Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 2, immagine 2 di 3 Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 2, immagine 3 di 3
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
    I fount that it worked best to start at the “top” of the keyboard. The lower portion had tabs into the housing
    it - Replica
  3. Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad 300-17ISK Keyboard Replacement: passo 3, immagine 2 di 2
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
Conclusione
Altre 3 persone hanno completato questa guida.
Ammar Dodin
Membro da: 01/19/17
1.057 Reputazione
6 Guide realizzate
UC Davis, Team 1-3, Rodger Winter 2017 Membro di UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Membri
6 Guide realizzate
Un commento
thank you so much very help full
deepak - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 5,514
