Introduzione
This guide demonstrates how to replace a faulty, damaged, or corrupt SSD in your Lenovo IdeaPad 3-15IGL05.
Hard drives are commonly a point of failure in electronic devices, and replacing one is a relatively simple procedure if done properly.
This replacement will take about 20 minutes, but it can be completed much faster than that if you know what you’re doing.
Cosa ti serve
Use a Phillips #0 screwdriver to remove the ten 7.6 mm screws securing the bottom panel.
