Salta al contenuto principale
Lenovo IdeaPad 3-15IGL05 SSD Replacement
Cosa ti serve
  1. Lenovo IdeaPad 3-15IGL05 SSD Replacement, SSD: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the ten 7.6 mm screws securing the bottom panel.
  2. Lenovo IdeaPad 3-15IGL05 SSD Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: passo 2, immagine 2 di 2
    • Wedge an opening tool in the gap between the bottom panel and chassis, and pry vertically around the perimeter until you hear a "pop" and the panel releases.
    • Lift the bottom panel up and off the chassis.
  3. Lenovo IdeaPad 3-15IGL05 SSD Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: passo 3, immagine 2 di 2
    • Locate the SSD at the bottom right corner of the fan.
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the SSD.
    • The drive should slightly lift once the screw is removed.
  4. Lenovo IdeaPad 3-15IGL05 SSD Replacement: passo 4, immagine 1 di 1
    • Gently pull the SSD directly out of its port.
    • Do not over-tighten the screws during reassembly.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 32
Tutti i Tempi: 4,121
