Introduzione
If the laptop begins to overheat, check to hear that there is a whirring noise when the laptop is turned on. If there is no noise, the laptop may go into a thermal cool down signifying a faulty cooling fan. This guide will walk you through how to change the cooling fan.
Cosa ti serve
Flip the IdeaPad bottom side up.
Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
Flip the computer back to top facing.
Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
Place the laptop bottom facing up.
Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
On the back panel, the cooling fan is located at the top right.
Unscrew the 6.0mm screw using the Phillips #1 screwdriver.
Push the plastic piece towards the direction the wires are in with the tweezers to completely disconnect it from the back panel.
