Salta al contenuto principale
Lenovo IdeaPad 110-15ISK Cooling Fan Replacement
Cosa ti serve
  1. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Keyboard: passo 1, immagine 1 di 1
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Optical Drive: passo 5, immagine 1 di 1
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Upper Case: passo 7, immagine 1 di 1
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement: passo 8, immagine 1 di 1
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
  8. Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Cooling Fan: passo 9, immagine 1 di 2 Lenovo IdeaPad 110-15ISK Cooling Fan Replacement, Cooling Fan: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • On the back panel, the cooling fan is located at the top right.
    • Unscrew the 6.0mm screw using the Phillips #1 screwdriver.
    • Push the plastic piece towards the direction the wires are in with the tweezers to completely disconnect it from the back panel.
Conclusione
Jakub Szark
Membro da: 10/17/18
513 Reputazione
5 Guide realizzate
UW Tacoma, Team S1-G5, Rose Fall 2018 Membro di UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
4 Membri
39 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,724
