Introduzione
This guide shows how to replace the optical drive for the Lenovo IdeaPad 110-15IBR. The guide shows how to remove the back panel, remove the screws holding the drive in place, and removing the optical drive from the docking port.
Cosa ti serve
Using #1 Phillips screwdriver remove the 13 (9mmx6mm) screws holding the back.
Gently pry the back off using a plastic opening tool, starting from one of the corners.
Altre 5 persone hanno completato questa guida.
Un commento
I think there is an easier way to remove the optical drive. You only need to remove the screw in the middle near optical drive. After this you can pull out the otpical drive.
How do we add the steps from the first time we removed the back from the computer? I keep forgetting what that is called but we need to use the same steps that we’ve used in previous guides.
Madison Burke - Replica
