Salta al contenuto principale
Introduzione
This guide will show how to replace the battery on the device. It walks through the process of removing the back, unscrewing the battery, and unplugging the batter from the device.
  1. Before you proceed, make sure your computer is turned off and it's not connected to any power source. Remove the thirteen 9 mm Phillips #1screws.
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Remove the thirteen 9 mm Phillips #1screws.
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
  2. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  3. Remove the two 9 mm Phillips #1 screws holding the battery.
    • Remove the two 9 mm Phillips #1 screws holding the battery.
  4. Disconnect the battery cable connector from mother board. Remove battery from device. Remove battery from device.
    • Disconnect the battery cable connector from mother board.
    • Remove battery from device.
Conclusione
Altre 6 persone hanno completato questa guida.
Saddam Alsinai
Membro da: 18/10/2017
553 Reputazione
4 Guide realizzate
UW Tacoma, Team S3-G4, Liner Fall 2017 Membro di UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
4 Membri
4 Guide realizzate
Informative except , you didn’t mention the three screws underneath the DVD drive. The DVD drive must be removed first before you can remove the 3 additional screws.
Clarey Ryan - Replica
I agree Clare! I didn’t see those either! Very frustrating at first! Thanks for the lead Clare!
Daniel Jansen - Replica
Just cannot see where theres 13 screws got 11 cant see anything under or near the Drive clare.
charlie.bansj - Replica
Easy to follow
Hugo Jhuboo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 126
Ultimi 30 Giorni: 780
Tutti i Tempi: 14,310
