Introduzione
This guide details the steps to remove the screen from the Lenovo IdeaPad 110 Touch- 15ACL laptop. The screen is the interface of the computer where processes can be visualized. If your screen is lagging or failing to properly display the computer’s contents. This device specifically has touchscreen configuration, be sure to use the exact same type of screen when replacing. The wire attaching to the screen is normally held in place with a strong tape to ensure a proper connection. Make sure this tape is replaced when reattaching. Exercise caution to mitigate damages to any other internal components.
Be sure to turn off your device and disconnect from the power adapter prior to beginning this repair.
Cosa ti serve
Open the laptop so the screen is facing you.
Use a pick or spudger to detach the clips around the screen holding the bezel in place.
Remove the bezel.
