Salta al contenuto principale
Lenovo IdeaPad 100s-14IBR Speaker Replacement
Cosa ti serve
  1. Lenovo IdeaPad 100s-14IBR Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Speaker Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 100s-14IBR Speaker Replacement: passo 2, immagine 2 di 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Speaker Replacement: passo 3, immagine 1 di 1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
    • Remove the six 4mm Phillips #00 screws.
    • Remove the battery using the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR Speaker Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad 100s-14IBR Speaker Replacement: passo 4, immagine 2 di 2
    • Unplug the speakers from the motherboard.
    • Remove the two 4mm PH00 screws from the metal shield on the trackpad.
    • Lift the metal shield up slightly, being very careful not to move the ribbon cables too much. Move the speaker cables out from under the shield.
  5. Lenovo IdeaPad 100s-14IBR Speaker Replacement: passo 5, immagine 1 di 1
    • Lift the speakers from the case being careful of the wires connecting them. Put them to the side.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 401
