Salta al contenuto principale
Lenovo IdeaPad 1 14IGL7 Speakers Replacement
Cosa ti serve
  1. Lenovo IdeaPad 1 14IGL7 Speakers Replacement, Back Panel: passo 1, immagine 1 di 1
    • Power off your laptop before beginning disassembly.
    • Place the computer upside down on a flat surface.
  2. Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 2, immagine 2 di 2
    • Remove the nine 7 mm screws from the back panel using a Phillips #00 screwdriver.
  3. Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 3, immagine 1 di 1
    • Insert an opening pick between the back panel and the body of the laptop.
    • Pry up the latches around the back panel and remove the panel from the laptop.
  4. Lenovo IdeaPad 1 14IGL7 Speakers Replacement, Battery: passo 4, immagine 1 di 2 Lenovo IdeaPad 1 14IGL7 Speakers Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the six 5.5 mm screws that secure the battery using a Phillips #00 screwdriver.
  5. Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 5, immagine 2 di 2
    • Gently pull on the cable attached to the motherboard in the same direction as the individual wires are running.
    • Be sure to ground yourself by wearing the anti-shock wristband to prevent damage to the components.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
  7. Lenovo IdeaPad 1 14IGL7 Speakers Replacement, Speakers: passo 7, immagine 1 di 1
    • Remove the three 3 mm screws that hold the metal bracket in place using a Phillips #00 screwdriver.
  8. Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 8, immagine 1 di 1
    • Carefully lift the metal bracket from the device and set it aside.
  9. Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 9, immagine 1 di 1
    • Remove the wire linking the two speakers by gently pulling it from the device, proceeding gradually.
    • Be careful not to damage the cable while trying to remove it from the device.
  10. Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 10, immagine 1 di 1
    • Gently pull on the wire that connects the speakers to the motherboard.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
  11. Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 11, immagine 1 di 2 Lenovo IdeaPad 1 14IGL7 Speakers Replacement: passo 11, immagine 2 di 2
    • For each of the two speakers, remove each end separately from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 54
