Salta al contenuto principale
Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement
Cosa ti serve
  1. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, Side Panel: passo 1, immagine 1 di 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: passo 2, immagine 1 di 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, USB 3.0 Expansion Card: passo 3, immagine 1 di 1
    • With your hands remove the 14mm screw that holds the cover on the back panel.
    • Gently pull the flap back to expose the expansion card retaining screw.
  4. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
  5. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: passo 5, immagine 1 di 1
    • With moderate force, pull straight up on the expansion card to remove it from the computer.
Conclusione
Altre 3 persone hanno completato questa guida.
Timothy Grebe
Membro da: 10/19/14
1.634 Reputazione
9 Guide realizzate
Cal Poly, Team 10-39, Amido Fall 2014 Membro di Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Membri
18 Guide realizzate
Un commento
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
TheLOD2010 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,117
