Salta al contenuto principale
Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement
Cosa ti serve
  1. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Stand Base: passo 1, immagine 1 di 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 2, immagine 1 di 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 2, immagine 2 di 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Back Cover: passo 3, immagine 1 di 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 4, immagine 1 di 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 4, immagine 2 di 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 4, immagine 3 di 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 5, immagine 1 di 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 5, immagine 2 di 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Arm Stand: passo 6, immagine 1 di 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Arm Stand: passo 6, immagine 2 di 2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 7, immagine 1 di 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 7, immagine 2 di 2
    • Lift up to remove the arm stand.
  8. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, EMI Cover: passo 8, immagine 1 di 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, EMI Cover: passo 8, immagine 2 di 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, EMI Cover: passo 8, immagine 3 di 3
    • Remove the 5 screws that secure the EMI cover.
    • Remove the cover.
  9. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, WiFi Card: passo 9, immagine 1 di 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, WiFi Card: passo 9, immagine 2 di 2
    • Remove any tape that secures the WiFi antenna cables.
  10. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 10, immagine 1 di 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 10, immagine 2 di 2
    • Remove the single screw that secures that WiFi card to the motherboard.
  11. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 11, immagine 1 di 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 11, immagine 2 di 2
    • Lift the wifi card and then pull out the card.
  12. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: passo 12, immagine 1 di 1
    • Locate the two small cables connected to the wifi card and pull gently to disconnect them.
Conclusione
Altre 2 persone hanno completato questa guida.
Jackson Blake
Membro da: 01/22/18
1.119 Reputazione
9 Guide realizzate
Cal Poly, Team S16-G3, Banghart Winter 2018 Membro di Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,547
