Salta al contenuto principale
Lenovo G780 Keyboard Replacement
Cosa ti serve
  1. Lenovo G780 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Lenovo G780 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Keyboard Replacement: passo 2, immagine 1 di 1
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the three 9mm keyboard screws with a #0 Phillips screwdriver.
  4. Lenovo G780 Keyboard Replacement: passo 4, immagine 1 di 3 Lenovo G780 Keyboard Replacement: passo 4, immagine 2 di 3 Lenovo G780 Keyboard Replacement: passo 4, immagine 3 di 3
    • With a plastic opening tool, start on the left of the keyboard and gently pry the keyboard off the laptop.
    • Be careful removing the keyboard to prevent from tearing the delicate connector.
  5. Lenovo G780 Keyboard Replacement: passo 5, immagine 1 di 3 Lenovo G780 Keyboard Replacement: passo 5, immagine 2 di 3 Lenovo G780 Keyboard Replacement: passo 5, immagine 3 di 3
    • Slightly lift the keyboard from the laptop.
    • Push the grey lock upward to unlock the ZIF connector.
    • Carefully lift the keyboard connector from its socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,440
