Salta al contenuto principale
Lenovo G780 Heat Sink Replacement
Cosa ti serve
  1. Lenovo G780 Heat Sink Replacement, Battery: passo 1, immagine 1 di 2 Lenovo G780 Heat Sink Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Heat Sink Replacement: passo 2, immagine 1 di 1
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Heat Sink Replacement, Fan: passo 3, immagine 1 di 3 Lenovo G780 Heat Sink Replacement, Fan: passo 3, immagine 2 di 3 Lenovo G780 Heat Sink Replacement, Fan: passo 3, immagine 3 di 3
    • Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
    • Save these screws.
    • Remove the back plate.
  4. Lenovo G780 Heat Sink Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #0 screwdriver to detach the fan by removing the two black 9 mm screws and the single silver 4 mm screw that is securing it to the motherboard.
  5. Lenovo G780 Heat Sink Replacement: passo 5, immagine 1 di 2 Lenovo G780 Heat Sink Replacement: passo 5, immagine 2 di 2
    • Carefully disconnect the fan cable from its socket on the motherboard.
    • The fan should now be completely free from the laptop motherboard and chassis.
  6. Lenovo G780 Heat Sink Replacement, Heat Sink: passo 6, immagine 1 di 3 Lenovo G780 Heat Sink Replacement, Heat Sink: passo 6, immagine 2 di 3 Lenovo G780 Heat Sink Replacement, Heat Sink: passo 6, immagine 3 di 3
    • Remove three 7mm spring loaded screws using a Phillips #1 screwdriver.
    • Remove these two 4 mm screws using a Phillips #1 screwdriver.
  7. Lenovo G780 Heat Sink Replacement: passo 7, immagine 1 di 2 Lenovo G780 Heat Sink Replacement: passo 7, immagine 2 di 2
    • The heat sink needs to be rotated counter-clockwise slightly to allow space for removal.
Conclusione
IUPUI, Team S2-G4, Henning Spring 2019 Membro di IUPUI, Team S2-G4, Henning Spring 2019
IUPUI-HENNING-S19S2G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 590
