Salta al contenuto principale
Lenovo G70-70 Fan Replacement
Cosa ti serve
  1. Lenovo G70-70 Fan Replacement, Battery: passo 1, immagine 1 di 2 Lenovo G70-70 Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure the battery is removed before attempting to fix anything on the laptop.
    • Orient the laptop so the bottom side is facing you.
    • To unlock the battery, place your thumb over the left switch and slide it to the left.
  2. Lenovo G70-70 Fan Replacement: passo 2, immagine 1 di 2 Lenovo G70-70 Fan Replacement: passo 2, immagine 2 di 2
    • To access the battery, place your thumb over the right switch and slide it to the right.
    • When the battery is unlocked, it will automatically pop up.
  3. Lenovo G70-70 Fan Replacement: passo 3, immagine 1 di 3 Lenovo G70-70 Fan Replacement: passo 3, immagine 2 di 3 Lenovo G70-70 Fan Replacement: passo 3, immagine 3 di 3
    • Remove the battery by lifting it up and away from yourself.
  4. Lenovo G70-70 Fan Replacement, Fan: passo 4, immagine 1 di 3 Lenovo G70-70 Fan Replacement, Fan: passo 4, immagine 2 di 3 Lenovo G70-70 Fan Replacement, Fan: passo 4, immagine 3 di 3
    • Turn your laptop so the bottom side is facing you.
    • Remove two 7.3 mm Phillips #0 screws.
    • Slide the back cover towards yourself.
  5. Lenovo G70-70 Fan Replacement: passo 5, immagine 1 di 3 Lenovo G70-70 Fan Replacement: passo 5, immagine 2 di 3 Lenovo G70-70 Fan Replacement: passo 5, immagine 3 di 3
    • Lift the back cover from the far side towards yourself to remove it.
    • Remove three 6.5 mm screws from the fan using a Phillips #0 screwdriver.
    • The label M2X6 will be located next to each screw.
  6. Lenovo G70-70 Fan Replacement: passo 6, immagine 1 di 3 Lenovo G70-70 Fan Replacement: passo 6, immagine 2 di 3 Lenovo G70-70 Fan Replacement: passo 6, immagine 3 di 3
    • Pinch both sides of the white connector and pull the cord from the socket.
    • Remove the fan from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 128
