Salta al contenuto principale
Lenovo G580 Keyboard Replacement
Cosa ti serve
  1. Lenovo G580 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Place the laptop so the bottom is facing up.
  2. Lenovo G580 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the two M2.5x4 screws connecting the removable plate to the frame of the computer using a Phillips #00 screwdriver.
  3. Lenovo G580 Keyboard Replacement: passo 3, immagine 1 di 1
    • Using both hands, slide the plate off of the back of the laptop.
  4. Lenovo G580 Keyboard Replacement: passo 4, immagine 1 di 1
    • Remove the three screws holding the keyboard to the laptop.
  5. Lenovo G580 Keyboard Replacement: passo 5, immagine 1 di 1
    • Open the lid of the laptop and locate the keyboard.
  6. Lenovo G580 Keyboard Replacement: passo 6, immagine 1 di 2 Lenovo G580 Keyboard Replacement: passo 6, immagine 2 di 2
    • Insert the plastic opening tool into the corner of the laptop between the keyboard and the side of the laptop.
    • Do not force the plastic opening tool as this will damage the laptop.
    • Slide the plastic opening tool across the keyboard towards the other corner.
  7. Lenovo G580 Keyboard Replacement: passo 7, immagine 1 di 1
    • Grab the keyboard at the corners and pull the keyboard off the laptop.
    • Make sure to disconnect the cord connecting the keyboard to the laptop before removing the keyboard.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 28
Tutti i Tempi: 4,069
