Salta al contenuto principale
Lenovo G580 Battery Replacement
Cosa ti serve
  1. Lenovo G580 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure your laptop is oriented backside facing upward as seen in the image.
    • Locate the battery lock switch.
  2. Lenovo G580 Battery Replacement: passo 2, immagine 1 di 2 Lenovo G580 Battery Replacement: passo 2, immagine 2 di 2
    • Unlock the battery by moving the switch to the right.
    • The switch is unlocked when the RED of the switch is present.
  3. Lenovo G580 Battery Replacement: passo 3, immagine 1 di 2 Lenovo G580 Battery Replacement: passo 3, immagine 2 di 2
    • Hold the release switch down.
    • At the same time, push the battery upwards to remove the battery.
    • Pulling on the battery while the battery is locked will damage the laptop. Ensure the lock is properly disengaged.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,740
