Salta al contenuto principale
Lenovo G575 Fan Replacement
Cosa ti serve
  1. Lenovo G575 Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Use the two switches to the left of and below the battery to unlock and release the battery.
    • The switch on the left should be moved to the left to unlock, then the switch on the right will release the battery.
    • Remove the battery from the laptop by lifting it out from its bay.
  2. Lenovo G575 Fan Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the five screws from the service panel on the right side.
    • Lift up the service panel.
  3. Lenovo G575 Fan Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the three silver screws holding the fan down.
    • Pull out the fan cable from its connector on the motherboard.
    • Lift the fan out of the case.
Conclusione
Samson Wong
Membro da: 09/21/20
103 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 872
