Salta al contenuto principale
Lenovo G50-80 80E5 Removing top panel Replacement
Cosa ti serve
  1. Lenovo G50-80 80E5 Removing top panel Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Removing top panel Replacement: passo 2, immagine 1 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 2, immagine 2 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 2, immagine 3 di 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Removing top panel Replacement: passo 3, immagine 1 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 3, immagine 2 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 3, immagine 3 di 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Removing top panel Replacement: passo 4, immagine 1 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 4, immagine 2 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 4, immagine 3 di 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: passo 5, immagine 1 di 2 Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: passo 5, immagine 2 di 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Removing top panel Replacement: passo 6, immagine 1 di 2 Lenovo G50-80 80E5 Removing top panel Replacement: passo 6, immagine 2 di 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: passo 7, immagine 1 di 3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: passo 7, immagine 2 di 3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: passo 7, immagine 3 di 3
    • Locate the 3 screws on the bottom securing the keyboard in place.
    • One Screw will be located under a Lenovo security sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Removing top panel Replacement: passo 8, immagine 1 di 1
    • Starting on the side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Removing top panel Replacement: passo 9, immagine 1 di 2 Lenovo G50-80 80E5 Removing top panel Replacement: passo 9, immagine 2 di 2
    • Continue prying around the top of the keyboard
  10. Lenovo G50-80 80E5 Removing top panel Replacement: passo 10, immagine 1 di 1
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Removing top panel Replacement: passo 11, immagine 1 di 1
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Removing top panel Replacement: passo 12, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Removing top panel Replacement: passo 13, immagine 1 di 2 Lenovo G50-80 80E5 Removing top panel Replacement: passo 13, immagine 2 di 2
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Removing top panel Replacement, Removing top panel: passo 14, immagine 1 di 1
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Removing top panel Replacement: passo 15, immagine 1 di 1
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Removing top panel Replacement: passo 16, immagine 1 di 1
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Removing top panel Replacement: passo 17, immagine 1 di 1
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Removing top panel Replacement: passo 18, immagine 1 di 1
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Removing top panel Replacement: passo 19, immagine 1 di 1
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Removing top panel Replacement: passo 20, immagine 1 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 20, immagine 2 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 20, immagine 3 di 3
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Removing top panel Replacement: passo 21, immagine 1 di 1
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Removing top panel Replacement: passo 22, immagine 1 di 2 Lenovo G50-80 80E5 Removing top panel Replacement: passo 22, immagine 2 di 2
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Removing top panel Replacement: passo 23, immagine 1 di 1
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Removing top panel Replacement: passo 24, immagine 1 di 1
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Removing top panel Replacement: passo 25, immagine 1 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 25, immagine 2 di 3 Lenovo G50-80 80E5 Removing top panel Replacement: passo 25, immagine 3 di 3
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Removing top panel Replacement: passo 26, immagine 1 di 1
    • Top covered removed
Conclusione
Altre 12 persone hanno completato questa guida.
Victor
Membro da: 10/17/17
1.309 Reputazione
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 59
Tutti i Tempi: 7,874
