Introduzione
This guide will show you how to unscrew and remove the power board button from your laptop.
Cosa ti serve
Place laptop on a flat surface with the back cover facing up and the hinges facing you.
Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
Locate the 3 screws on the bottom, securing the keyboard.
One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
At this point in disassembly, there will be one #00x5.5 mm screw securing the power button board in place.
Take your screwdriver and remove the screw.
Take your tweezers and grip the power button board.
Using tweezers, lift power button board up and out. The cable wire for the power button board should be disconnected at this point and the piece should lift out without any extra work needed.
Altre 2 persone hanno completato questa guida.
