Salta al contenuto principale
Lenovo G50-80 80E5 Motherboard Replacement
Cosa ti serve
  1. Lenovo G50-80 80E5 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Lenovo G50-80 80E5 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • From the underside of the laptop, press the two battery tabs inward to remove the battery. Lift the battery to remove.
  2. Lenovo G50-80 80E5 Motherboard Replacement: passo 2, immagine 1 di 2 Lenovo G50-80 80E5 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the three #00x5.5mm screws from the bottom front under panel and then slide the main access panel forward and out.
  3. Lenovo G50-80 80E5 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the two #00x4.5mm screws from the hard drive and then slide the drive to the side and remove the hard drive.
  4. Lenovo G50-80 80E5 Motherboard Replacement: passo 4, immagine 1 di 2 Lenovo G50-80 80E5 Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the three #00x5.5mm screws from the fan unit, unplug the fan wiring connector and then remove the fan unit.
  5. Lenovo G50-80 80E5 Motherboard Replacement: passo 5, immagine 1 di 1
    • Use tweezers to carefully remove the white and black wires from the WiFi card. Thread the wires back out of it's channel and hold to the side.
  6. Lenovo G50-80 80E5 Motherboard Replacement: passo 6, immagine 1 di 1
    • Unplug the two ribbon cables from under the fan unit area.
  7. Lenovo G50-80 80E5 Motherboard Replacement: passo 7, immagine 1 di 2 Lenovo G50-80 80E5 Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove the CD Drive fixing screw (#00x5.5mm) and slide the drive out from it's slot.
  8. Lenovo G50-80 80E5 Motherboard Replacement: passo 8, immagine 1 di 3 Lenovo G50-80 80E5 Motherboard Replacement: passo 8, immagine 2 di 3 Lenovo G50-80 80E5 Motherboard Replacement: passo 8, immagine 3 di 3
    • Release the RAM fixing clip from both ends of each RAM chip. Once released, slide out each RAM chip.
  9. Lenovo G50-80 80E5 Motherboard Replacement: passo 9, immagine 1 di 3 Lenovo G50-80 80E5 Motherboard Replacement: passo 9, immagine 2 di 3 Lenovo G50-80 80E5 Motherboard Replacement: passo 9, immagine 3 di 3
    • Remove the three #00x5.5mm screws holding the keyboard.
  10. Lenovo G50-80 80E5 Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the six perimeter #00x5.5mm screws holding the palm rest.
  11. Lenovo G50-80 80E5 Motherboard Replacement: passo 11, immagine 1 di 1
    • Flip the laptop over, lift the screen and with a plastic spudger begin to remove the keyboard. Start at the top left corner and work from left to right lifting the keyboard. Once the top section is free, lift the keyboard up and away from yourself. Remove the ribbon cable connection and set the keyboard aside.
  12. Lenovo G50-80 80E5 Motherboard Replacement: passo 12, immagine 1 di 3 Lenovo G50-80 80E5 Motherboard Replacement: passo 12, immagine 2 di 3 Lenovo G50-80 80E5 Motherboard Replacement: passo 12, immagine 3 di 3
    • Disconnect the two ribbon cables then using a plastic spudger, begin to separate the the palm rest from the chassis. Start along the front left edge and work left to right to separate each half. Separate the left and right sides in the same fashion.
  13. Lenovo G50-80 80E5 Motherboard Replacement: passo 13, immagine 1 di 2 Lenovo G50-80 80E5 Motherboard Replacement: passo 13, immagine 2 di 2
    • Disconnect the CD Drive ribbon cable and the auxiliary board cable. Disconnect the speaker cable and then remove the CD Drive board fixing screw (#00x4.5mm). Remove the auxiliary board fixing screw and then remove the auxiliary board.
  14. Lenovo G50-80 80E5 Motherboard Replacement: passo 14, immagine 1 di 3 Lenovo G50-80 80E5 Motherboard Replacement: passo 14, immagine 2 di 3 Lenovo G50-80 80E5 Motherboard Replacement: passo 14, immagine 3 di 3
    • Remove the three motherboard fixing screws (#00x5.5mm) and remove the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Sean Mullin
Membro da: 10/17/17
208 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 34
Tutti i Tempi: 8,093
