Salta al contenuto principale
Lenovo G50-80 80E5 Hard Drive Replacement
Cosa ti serve
  1. Lenovo G50-80 80E5 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Hard Drive Replacement: passo 2, immagine 1 di 3 Lenovo G50-80 80E5 Hard Drive Replacement: passo 2, immagine 2 di 3 Lenovo G50-80 80E5 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Hard Drive Replacement: passo 3, immagine 1 di 3 Lenovo G50-80 80E5 Hard Drive Replacement: passo 3, immagine 2 di 3 Lenovo G50-80 80E5 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Hard Drive Replacement: passo 4, immagine 1 di 3 Lenovo G50-80 80E5 Hard Drive Replacement: passo 4, immagine 2 di 3 Lenovo G50-80 80E5 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Hard Drive Replacement, Bottom Access Panel: passo 5, immagine 1 di 2 Lenovo G50-80 80E5 Hard Drive Replacement, Bottom Access Panel: passo 5, immagine 2 di 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Hard Drive Replacement: passo 6, immagine 1 di 2 Lenovo G50-80 80E5 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 1
    • Rotate the laptop until you are positioned over the hard drive.
  8. Lenovo G50-80 80E5 Hard Drive Replacement: passo 8, immagine 1 di 1
    • Use the #00 Phillips screwdriver to remove the four 5.5mm screws around the hard drive.
  9. Lenovo G50-80 80E5 Hard Drive Replacement: passo 9, immagine 1 di 1
    • Slide the hard drive towards yourself and remove it.
Conclusione
If you would like to reassemble your device, please follow these instructions in reverse order.
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 996
