Salta al contenuto principale
Lenovo G50-80 80E5 Battery Replacement
  1. Lenovo G50-80 80E5 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Battery Replacement: passo 2, immagine 1 di 3 Lenovo G50-80 80E5 Battery Replacement: passo 2, immagine 2 di 3 Lenovo G50-80 80E5 Battery Replacement: passo 2, immagine 3 di 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Battery Replacement: passo 3, immagine 1 di 3 Lenovo G50-80 80E5 Battery Replacement: passo 3, immagine 2 di 3 Lenovo G50-80 80E5 Battery Replacement: passo 3, immagine 3 di 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Battery Replacement: passo 4, immagine 1 di 3 Lenovo G50-80 80E5 Battery Replacement: passo 4, immagine 2 di 3 Lenovo G50-80 80E5 Battery Replacement: passo 4, immagine 3 di 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
Conclusione
Altre 4 persone hanno completato questa guida.
Abigail Hood
Membro da: 10/17/17
387 Reputazione
2 Guide realizzate
Un commento
I purchased a new battery. I think I have not put the new one correctly. It does not align right. The computer is working fine. But it does not charge until I place a couple of books under the battery case, to kind of keep it in place..
Ashish Nelson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 4,501
