Salta al contenuto principale
Lenovo G40-30 Speaker Replacement
Cosa ti serve
  1. Lenovo G40-30 Speaker Replacement, Battery: passo 1, immagine 1 di 3 Lenovo G40-30 Speaker Replacement, Battery: passo 1, immagine 2 di 3 Lenovo G40-30 Speaker Replacement, Battery: passo 1, immagine 3 di 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 Speaker Replacement: passo 2, immagine 1 di 3 Lenovo G40-30 Speaker Replacement: passo 2, immagine 2 di 3 Lenovo G40-30 Speaker Replacement: passo 2, immagine 3 di 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 Speaker Replacement: passo 3, immagine 1 di 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 Speaker Replacement, Keyboard: passo 4, immagine 1 di 2 Lenovo G40-30 Speaker Replacement, Keyboard: passo 4, immagine 2 di 2
    • Use a JIS #1 screwdriver to remove the two 7 mm screws.
  5. Lenovo G40-30 Speaker Replacement: passo 5, immagine 1 di 2 Lenovo G40-30 Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the back panel by sliding it away from the battery.
  6. Lenovo G40-30 Speaker Replacement: passo 6, immagine 1 di 1
    • Use a JIS #1 screwdriver to remove the three 7 mm screws.
  7. Lenovo G40-30 Speaker Replacement: passo 7, immagine 1 di 2 Lenovo G40-30 Speaker Replacement: passo 7, immagine 2 di 2
    • Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
    • Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
    • The keyboard should only be connected by a ribbon on the underside of the keyboard.
    • It is recommended that you slowly pull the keyboard out as your move around the edge. As in picture 2.
    • Be careful not to pull the keyboard too far away from the face as it will damage the data ribbon.
  8. Lenovo G40-30 Speaker Replacement: passo 8, immagine 1 di 3 Lenovo G40-30 Speaker Replacement: passo 8, immagine 2 di 3 Lenovo G40-30 Speaker Replacement: passo 8, immagine 3 di 3
    • Use the tweezers to lift the black hinge on the ribbon connector.
    • Then pull the ribbon from the connector and remove the keyboard from the laptop.
  9. Lenovo G40-30 Speaker Replacement: passo 9, immagine 1 di 1
    • Now your keyboard is free to be replaced!
  10. Lenovo G40-30 Speaker Replacement, Hard Drive: passo 10, immagine 1 di 2 Lenovo G40-30 Speaker Replacement, Hard Drive: passo 10, immagine 2 di 2
    • Unscrew four 4mm JIS #0 screws.
  11. Lenovo G40-30 Speaker Replacement: passo 11, immagine 1 di 3 Lenovo G40-30 Speaker Replacement: passo 11, immagine 2 di 3 Lenovo G40-30 Speaker Replacement: passo 11, immagine 3 di 3
    • After you have the screws out apply pressure with your thumb and slide the hard drive to the left.
    • When the hard drive is completely left gently pull up on the right corner.
  12. Lenovo G40-30 Speaker Replacement, Speaker: passo 12, immagine 1 di 2 Lenovo G40-30 Speaker Replacement, Speaker: passo 12, immagine 2 di 2
    • Remove the nine 7mm screws with a JIS #0 screwdriver.
  13. Lenovo G40-30 Speaker Replacement: passo 13, immagine 1 di 1
    • Using the plastic opening tool split open the laptop on the ends. Starting from one side to the other.
  14. Lenovo G40-30 Speaker Replacement: passo 14, immagine 1 di 3 Lenovo G40-30 Speaker Replacement: passo 14, immagine 2 di 3 Lenovo G40-30 Speaker Replacement: passo 14, immagine 3 di 3
    • These two are the speakers.
    • This is the connector.
    • Unscrew the two 4mm JIS #0 screws.
  15. Lenovo G40-30 Speaker Replacement: passo 15, immagine 1 di 3 Lenovo G40-30 Speaker Replacement: passo 15, immagine 2 di 3 Lenovo G40-30 Speaker Replacement: passo 15, immagine 3 di 3
    • In order to remove the speakers you must first pull back the blue circuitry that covers the speakers.
    • Then, remove the left speaker by pulling it up and off the prongs holding it. Repeat this step for the right side
    • Next, use the tweezers to pull the connector out away from the screen.
  16. Lenovo G40-30 Speaker Replacement: passo 16, immagine 1 di 1
    • Now you are ready to install your new speakers.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,528
