Salta al contenuto principale
Lenovo G40-30 Keyboard Replacement
Cosa ti serve
  1. Lenovo G40-30 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Lenovo G40-30 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Lenovo G40-30 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 Keyboard Replacement: passo 2, immagine 1 di 3 Lenovo G40-30 Keyboard Replacement: passo 2, immagine 2 di 3 Lenovo G40-30 Keyboard Replacement: passo 2, immagine 3 di 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 Keyboard Replacement: passo 3, immagine 1 di 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 2 Lenovo G40-30 Keyboard Replacement, Keyboard: passo 4, immagine 2 di 2
    • Use a JIS #1 screwdriver to remove the two 7 mm screws.
  5. Lenovo G40-30 Keyboard Replacement: passo 5, immagine 1 di 2 Lenovo G40-30 Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the back panel by sliding it away from the battery.
  6. Lenovo G40-30 Keyboard Replacement: passo 6, immagine 1 di 1
    • Use a JIS #1 screwdriver to remove the three 7 mm screws.
  7. Lenovo G40-30 Keyboard Replacement: passo 7, immagine 1 di 2 Lenovo G40-30 Keyboard Replacement: passo 7, immagine 2 di 2
    • Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
    • Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
    • The keyboard should only be connected by a ribbon on the underside of the keyboard.
    • It is recommended that you slowly pull the keyboard out as your move around the edge. As in picture 2.
    • Be careful not to pull the keyboard too far away from the face as it will damage the data ribbon.
  8. Lenovo G40-30 Keyboard Replacement: passo 8, immagine 1 di 3 Lenovo G40-30 Keyboard Replacement: passo 8, immagine 2 di 3 Lenovo G40-30 Keyboard Replacement: passo 8, immagine 3 di 3
    • Use the tweezers to lift the black hinge on the ribbon connector.
    • Then pull the ribbon from the connector and remove the keyboard from the laptop.
  9. Lenovo G40-30 Keyboard Replacement: passo 9, immagine 1 di 1
    • Now your keyboard is free to be replaced!
Conclusione
Altre 2 persone hanno completato questa guida.
Luke
Membro da: 02/08/18
314 Reputazione
1 Guida realizzata
Un commento
thanks ….terimakasih sangat membantu…..
herman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,076
