Salta al contenuto principale
Lenovo Flex 6-11IGM Motherboard Replacement
Cosa ti serve
  1. Lenovo Flex 6-11IGM Motherboard Replacement, Back Panel: passo 1, immagine 1 di 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Motherboard Replacement: passo 2, immagine 1 di 2 Lenovo Flex 6-11IGM Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Motherboard Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Motherboard Replacement: passo 4, immagine 1 di 2 Lenovo Flex 6-11IGM Motherboard Replacement: passo 4, immagine 2 di 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Attenzione: i passaggi 5-7 provengono da una guida contrassegnata come in corso.
    Lenovo Flex 6-11IGM Motherboard Replacement, RAM: passo 5, immagine 1 di 2 Lenovo Flex 6-11IGM Motherboard Replacement, RAM: passo 5, immagine 2 di 2
    • Insert a plastic opening pick in the ribbon cable housing, flip the black part up, and pull the cable out with your fingers.
  6. Lenovo Flex 6-11IGM Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the four 3.5mm Phillips #0 screws that secure the heat sink.
    • Remove the four 3.5 mm Phillips #0 screws that secure the heat sink.
  7. Lenovo Flex 6-11IGM Motherboard Replacement: passo 7, immagine 1 di 1
    • Ram chips are soldered onto motherboard and cannot be removed.
  8. Lenovo Flex 6-11IGM Motherboard Replacement, Motherboard: passo 8, immagine 1 di 1
    • Disengage the cable located above the left speaker.
    • Disengage the ribbon cable located directly above the battery using the blue pick.
    • Disengage the battery cable directly above the ribbon cable housing.
    • Disengage the CMOS battery cable located to the right of the battery cable.
    • Remove the display cable located directly above the button battery.
    • Disengage the secondary display cable located directly to the left of the display cable.
  9. Lenovo Flex 6-11IGM Motherboard Replacement: passo 9, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the five 3.5 mm screws that secure the motherboard.
    • Using a Phillips #0 screwdriver, remove the one 3.5 mm screw that secures the Wi-Fi chip, located above the button battery.
  10. Lenovo Flex 6-11IGM Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the Wi-Fi chip located above the button battery from the motherboard.
    • Remove the motherboard from the case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,037
