Salta al contenuto principale
Lenovo Flex 6-11IGM Heat Sink Replacement
Cosa ti serve
  1. Lenovo Flex 6-11IGM Heat Sink Replacement, Back Panel: passo 1, immagine 1 di 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 2, immagine 1 di 2 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 2, immagine 2 di 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 4, immagine 1 di 2 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 4, immagine 2 di 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: passo 5, immagine 1 di 2 Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 6, immagine 1 di 3 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 6, immagine 2 di 3 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 6, immagine 3 di 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 7, immagine 1 di 1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: passo 8, immagine 1 di 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: passo 8, immagine 2 di 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: passo 8, immagine 3 di 3
    • Disconnect the ribbon connector from both ends by disengaging the black latch and pulling it directly from its port.
  9. Lenovo Flex 6-11IGM Heat Sink Replacement: passo 9, immagine 1 di 2 Lenovo Flex 6-11IGM Heat Sink Replacement: passo 9, immagine 2 di 2
    • Remove the 3.5 mm length screws in the numbered order from 1-10 using the Phillips #00 screwdriver (not all are shown in the first image).
    • Remove the heat sink.
Conclusione
Rie Kuraoka
Membro da: 01/23/20
886 Reputazione
7 Guide realizzate
Cal Poly, Team S7-G10, Paton Spring 2020 Membro di Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 301
