Salta al contenuto principale
Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement
Cosa ti serve
  1. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Back Panel: passo 1, immagine 1 di 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: passo 2, immagine 1 di 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: passo 2, immagine 2 di 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: passo 4, immagine 1 di 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: passo 4, immagine 2 di 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: passo 5, immagine 1 di 3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: passo 5, immagine 2 di 3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: passo 5, immagine 3 di 3
    • Disconnect the ribbon connector using the iFixit opening tool tool by flipping up the black flap and pulling the ribbon out.
  6. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: passo 6, immagine 1 di 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: passo 6, immagine 2 di 2
    • Take the three 3.5mm silver screws out using the Phillips #00 screwdriver.
    • Remove the protective silver shield before removing the ports.
    • Using the iFixit opening tool, insert its end underneath the ports, and pull them upwards toward you to remove them safely.
Conclusione
Rie Kuraoka
Membro da: 01/23/20
886 Reputazione
7 Guide realizzate
Cal Poly, Team S7-G10, Paton Spring 2020 Membro di Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 387
