Salta al contenuto principale
Lenovo Flex 3-1120 Hard Drive Replacement
Cosa ti serve
  1. Lenovo Flex 3-1120 Hard Drive Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Hard Drive Replacement: passo 2, immagine 1 di 2 Lenovo Flex 3-1120 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Locate the hard drive in the bottom left of your computer.
  6. Lenovo Flex 3-1120 Hard Drive Replacement: passo 6, immagine 1 di 2 Lenovo Flex 3-1120 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Locate the three 3.5mm Phillips screws on the corners of the hard drive.
    • Remove the three screws with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Follow the wire out from the right side of the hard drive to locate where the hard drive connects to the motherboard.
  8. Lenovo Flex 3-1120 Hard Drive Replacement: passo 8, immagine 1 di 1
    • Lift off the strip of tape securing the wire down to the computer.
  9. Lenovo Flex 3-1120 Hard Drive Replacement: passo 9, immagine 1 di 1
    • Pull the connector out of its port on the motherboard.
  10. Lenovo Flex 3-1120 Hard Drive Replacement: passo 10, immagine 1 di 1
    • Lift the hard drive out from the computer.
Conclusione
Altre 8 persone hanno completato questa guida.
Geoff Bentz
Membro da: 03/09/16
961 Reputazione
5 Guide realizzate
4Commenti sulla guida
How do you reload operating system.... for example windows 10?
supermac200 - Replica
How do I get Windows 10 working again after replacing hard drive on Lenovo Flex 3?
arcinko - Replica
Demo models of this do not have any SATA connector.
Elilla Shadowheart - Replica
That sata connector is the worst thing ever
dilleremail - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 11,368
