Salta al contenuto principale
Lenovo Flex 2-15 Daughterboard Replacement
Cosa ti serve
  1. Lenovo Flex 2-15 Daughterboard Replacement, Battery: passo 1, immagine 1 di 1
    • Begin by taking the back plate off of your device. Using a Phillips head screw driver, take out the highlighted screws for your device.
  2. Lenovo Flex 2-15 Daughterboard Replacement: passo 2, immagine 1 di 1
    • Remove battery from the motherboard by unplugging the cord and removing the screws.
  3. Lenovo Flex 2-15 Daughterboard Replacement: passo 3, immagine 1 di 1
    • Once you have the battery removed, locate the cable for your new battery and connect it on the same port from your old battery. Secure it onto the laptop by using the screws. After this step is complete, complete step 1 in reverse order to secure the plate cover over your motherboard.
  4. Lenovo Flex 2-15 Daughterboard Replacement, Daughterboard: passo 4, immagine 1 di 2 Lenovo Flex 2-15 Daughterboard Replacement, Daughterboard: passo 4, immagine 2 di 2
    • Flip up the black ZIF locking flap. Disconnect the ribbon cable.
  5. Lenovo Flex 2-15 Daughterboard Replacement: passo 5, immagine 1 di 2 Lenovo Flex 2-15 Daughterboard Replacement: passo 5, immagine 2 di 2
    • Remove the two 4 mm Phillips #00 screws that secure the daughterboard.
  6. Lenovo Flex 2-15 Daughterboard Replacement: passo 6, immagine 1 di 1
    • Grab the daughterboard with your fingers and lift it straight up and out of the chassis.
Conclusione
Austin
Membro da: 09/23/24
97 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 100
