Salta al contenuto principale
Lenovo Essential G570 Fan Replacement
Cosa ti serve
  1. Lenovo Essential G570 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Lenovo Essential G570 Fan Replacement: passo 2, immagine 1 di 2 Lenovo Essential G570 Fan Replacement: passo 2, immagine 2 di 2
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Lenovo Essential G570 Fan Replacement: passo 3, immagine 1 di 2 Lenovo Essential G570 Fan Replacement: passo 3, immagine 2 di 2
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
  4. Lenovo Essential G570 Fan Replacement, Back Panel: passo 4, immagine 1 di 1
    • Turn the laptop over so that the bottom side is facing up.
  5. Lenovo Essential G570 Fan Replacement: passo 5, immagine 1 di 1
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  6. Lenovo Essential G570 Fan Replacement: passo 6, immagine 1 di 3 Lenovo Essential G570 Fan Replacement: passo 6, immagine 2 di 3 Lenovo Essential G570 Fan Replacement: passo 6, immagine 3 di 3
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
  7. Lenovo Essential G570 Fan Replacement, Fan: passo 7, immagine 1 di 2 Lenovo Essential G570 Fan Replacement, Fan: passo 7, immagine 2 di 2
    • Carefully pull the fan's power connector from the laptop.
  8. Lenovo Essential G570 Fan Replacement: passo 8, immagine 1 di 2 Lenovo Essential G570 Fan Replacement: passo 8, immagine 2 di 2
    • Remove the three 5mm Phillips #1 screws holding the fan in place.
  9. Lenovo Essential G570 Fan Replacement: passo 9, immagine 1 di 2 Lenovo Essential G570 Fan Replacement: passo 9, immagine 2 di 2
    • Remove the fan by pulling it up and away from the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
Lucio
Membro da: 03/06/18
217 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 524
