Salta al contenuto principale
Lenovo Essential G560 Battery Replacement
  1. Lenovo Essential G560 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Battery Replacement: passo 2, immagine 1 di 2 Lenovo Essential G560 Battery Replacement: passo 2, immagine 2 di 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Battery Replacement: passo 3, immagine 1 di 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Conclusione
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
Altre 14 persone hanno completato questa guida.
Dennis Wong
Membro da: 01/11/13
609 Reputazione
5 Guide realizzate
Cal Poly, Team 18-40, Regan Winter 2013 Membro di Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 20
Tutti i Tempi: 5,589
