Salta al contenuto principale
Lenovo Essential G555-0873 RAM Replacement
Cosa ti serve
  1. Lenovo Essential G555-0873 RAM Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 RAM Replacement: passo 2, immagine 1 di 1
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 RAM Replacement, RAM: passo 3, immagine 1 di 3 Lenovo Essential G555-0873 RAM Replacement, RAM: passo 3, immagine 2 di 3 Lenovo Essential G555-0873 RAM Replacement, RAM: passo 3, immagine 3 di 3
    • Push apart hinges shown in picture until RAM pushes itself up to approximately a 30 degree angle.
  4. Lenovo Essential G555-0873 RAM Replacement: passo 4, immagine 1 di 1
    • Pull the RAM stick out of its socket.
  5. Lenovo Essential G555-0873 RAM Replacement: passo 5, immagine 1 di 1
    • Push apart hinges of lower RAM stick until it pops up to a similar angle.
  6. Lenovo Essential G555-0873 RAM Replacement: passo 6, immagine 1 di 1
    • Pull out second RAM stick in the same way as the first.
  7. Lenovo Essential G555-0873 RAM Replacement: passo 7, immagine 1 di 2 Lenovo Essential G555-0873 RAM Replacement: passo 7, immagine 2 di 2
    • Push RAM sticks in diagonally, then push down and snap it in with hinges.
    • Make sure that the RAM stick is aligned with the notch on the port when inserting it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 245
