Salta al contenuto principale
Lenovo Essential G555-0873 CPU Replacement
Cosa ti serve
  1. Lenovo Essential G555-0873 CPU Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 CPU Replacement: passo 2, immagine 1 di 1
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 CPU Replacement, Fan: passo 3, immagine 1 di 1
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Lenovo Essential G555-0873 CPU Replacement: passo 4, immagine 1 di 1
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Lenovo Essential G555-0873 CPU Replacement: passo 5, immagine 1 di 1
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Lenovo Essential G555-0873 CPU Replacement, Heat Sink: passo 6, immagine 1 di 1
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Lenovo Essential G555-0873 CPU Replacement: passo 7, immagine 1 di 2 Lenovo Essential G555-0873 CPU Replacement: passo 7, immagine 2 di 2
    • Pull the heat sink assembly out of the laptop.
  8. Lenovo Essential G555-0873 CPU Replacement, CPU: passo 8, immagine 1 di 2 Lenovo Essential G555-0873 CPU Replacement, CPU: passo 8, immagine 2 di 2
    • Use a flat-head screwdriver on the hinge shown, and turn counter-clockwise to the unlock position
  9. Lenovo Essential G555-0873 CPU Replacement: passo 9, immagine 1 di 1
    • Remove the CPU
    • There will be old thermal paste on the CPU and heat sink which should be wiped off using microfiber cloth.
    • Before putting the heat sink back in, a small droplet of thermal paste should be applied onto the center of the CPU.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 383
