Introduzione
The guide will show you how to remove the motherboard from the laptop. The process requires a lot of disarming, and a place to safely deposit screws is recommended.
  1. Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Using a plastic opening tool, pull out the back panel from the laptop.
    • Using a plastic opening tool, pull out the back panel from the laptop.
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
    • Pull the battery outward and remove it from the rest of the laptop.
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
    • Use a plastic opening tool as a lever to separate the hard drive from its casing .
    • Carefully, using your hand, remove the hard drive from the laptop.
    • Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
    • The network card will pop up by itself.
    • Grab the network card and gently pull it out.
    • Pull out the RAM metallic cover.
    • Grab the black insulating tape and pull it out.
    • Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
    • (5) Five copper and (1) one silver Phillips #0 5.4mm screws.
    • Disconnect the fan from the motherboard.
    • Unplug the Fan connector from its socket on the motherboard.
    • Carefully remove the fan from the laptop.
    • Using the Phillips #0 screwdriver, remove the (2) two 5.4 mm Phillips screws.
    • Disconnect these connectors from the motherboard.
    • Disconnect the four ribbon cables from the motherboard.
    • Unscrew and remove the (2) two Phillips #0 screws.
    • Lift up the black latch of the ribbon cable with the brown tab on top by holding the cable in to the motherboard.
    • Grab the tab with a pair of pliers and pull out the cable.
    • Lift the beige latch of the ribbon cable with the blue tab by holding the cable in to the motherboard, and with a pair of tweezers, pull out the cable.
    • Lift up the black latch of the ribbon cable with the blue tab at the lower right corner of the motherboard and disconnect it with a pair of tweezers.
    • Grab the tab and pull out the cable.
    • Locate the last ribbon cable with a blue tab and lift the beige latch holding the cable in to the motherboard.
    • With a pair of tweezers grab the tab and remove the cable.
    • Lift the black latch of the black connector at the top left corner of the motherboard by holding it in to the motherboard.
    • Grab the cable and pull it outwards to remove it.
    • Pull the wire besides the brown tab ribbon cable out and disconnect it.
    • Grab the small black connector by the RAM module and disconnect it from the motherboard.
    • Unplug the remaining connector besides the RAM module and remove it from the motherboard.
    • Gently grab the motherboard and pull it up lightly. Then pull it towards you and remove the motherboard.
Conclusione
Julian Escallon
Membro da: 27/09/2017
564 Reputazione
5 Guide realizzate
USF Tampa, Team S14-G1, Boczar Fall 2017 Membro di USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 46
Tutti i Tempi: 748
