Introduzione
The guide will show you how to remove the battery from the laptop. The removal of the battery is necessary to do any work inside the laptop for safety purposes.
Parti
Nessuna parte richiesta.
  1. Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel. Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Using a plastic opening tool, pull out the back panel from the laptop. Using a plastic opening tool, pull out the back panel from the laptop.
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws. Disconnect the battery connector from the motherboard. Disconnect the battery connector from the motherboard.
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  5. Pull the battery outward and remove it from the rest of the laptop.
    • Pull the battery outward and remove it from the rest of the laptop.
Conclusione
Julian Escallon
Membro da: 27/09/2017
609 Reputazione
5 Guide realizzate
USF Tampa, Team S14-G1, Boczar Fall 2017 Membro di USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 61
Tutti i Tempi: 1,330
