Salta al contenuto principale
Lenovo Edge 15 LCD Screen Replacement
Cosa ti serve
  1. Lenovo Edge 15 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Remove the black plastic or rubber screw caps covering screws, located at the bottom of the screen
  2. Lenovo Edge 15 LCD Screen Replacement: passo 2, immagine 1 di 2 Lenovo Edge 15 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Remove the (2) M2.5 × 2.5 mm, Black Phillips Nylok coated screws with the Phillips #1 screwdriver, located on either side of the bottom of the screen.
  3. Lenovo Edge 15 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Pry apart plastic cover at the bottom of the screen from plastic hinge cover.
  4. Lenovo Edge 15 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the (1) M2.5 x 2.5mm Black Phillips, Nylok coated screw located near the bottom center of the screen with the Phillips #1 screwdriver.
  5. Lenovo Edge 15 LCD Screen Replacement: passo 5, immagine 1 di 2 Lenovo Edge 15 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Slide LCD screen around the edges while pulling upwards so that it pops off.
    • Turn the screen over so the touch board is visible, and start working from the back of the screen.
    • Ribbons will be connected in the back of the screen, so be careful not to pull too far that they rip out.
  6. Lenovo Edge 15 LCD Screen Replacement: passo 6, immagine 1 di 2 Lenovo Edge 15 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Unplug the sensor from the sensor board near the bottom left of behind the screen.
  7. Lenovo Edge 15 LCD Screen Replacement: passo 7, immagine 1 di 2 Lenovo Edge 15 LCD Screen Replacement: passo 7, immagine 2 di 2
    • Disconnect the two ribbons from connectors from the same board from the previous step, near the bottom left of the behind the screen.
    • The ribbon connectors unlatch by pulling up on the very small brown plastic bar near the end of the ribbon.
    • Be careful not to pull on the ribbons before unlatching. This may damage the connector and/or ribbons.
  8. Lenovo Edge 15 LCD Screen Replacement: passo 8, immagine 1 di 2 Lenovo Edge 15 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Remove the tape covering a ribbon connector near the bottom of the screen.
    • Disconnect the ribbon by pulling back the small grey latch on the connector and gently pulling the ribbon away.
  9. Lenovo Edge 15 LCD Screen Replacement: passo 9, immagine 1 di 3 Lenovo Edge 15 LCD Screen Replacement: passo 9, immagine 2 di 3 Lenovo Edge 15 LCD Screen Replacement: passo 9, immagine 3 di 3
    • Remove LCD screen by gently pulling screen away from the rest of the laptop.
    • Make sure all connections are secure when installing new screen. This eliminates the connection issue if screen is still not working properly after installation.
Conclusione
Altre 7 persone hanno completato questa guida.
Gracie Harder
Membro da: 09/27/17
311 Reputazione
1 Guida realizzata
Cal Poly, Team S8-G1, Banghart Fall 2017 Membro di Cal Poly, Team S8-G1, Banghart Fall 2017
CPSU-BANGHART-F17S8G1
5 Membri
7 Guide realizzate
5Commenti sulla guida
Does the lcd separate from the digitizer screen or do both need to be replaced if the digitizer is cracked?
Sylvia Gagne - Replica
Typically one can separate the LCD from the glass, but it is a difficult and painful process, and it almost always cracks the LCD. If the cost is not prohibitively expensive, I would just replace them together as one unit.
Allan Wilson -
I need that exact bottom frame strip piece replaced that they are showing in the first picture. Does anyone know where I can order one?
Josselyn Santiago - Replica
looking to replace the whole screen, if possible even the hinge.
nasty bent screen I have for over 2+ years and I want to change that. Any advice welcomed.
frame is bent, Glass is broken in corner, touch screen gone.
Wouldnt care to install digitizer back but if I can see how to install screen components that be good.
Carry on.
Simarpreet Singh - Replica
que tal joven talvez usted consiguió la pantalla y en que precio por que también tengo el mismo problema quiero cambiar toda la pantalla.
ToplayVid :v -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 68
Tutti i Tempi: 11,326
