Salta al contenuto principale
Lenovo B575-1450 RAM Replacement
Cosa ti serve
  1. Lenovo B575-1450 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 RAM Replacement: passo 2, immagine 1 di 2 Lenovo B575-1450 RAM Replacement: passo 2, immagine 2 di 2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 RAM Replacement: passo 3, immagine 1 di 3 Lenovo B575-1450 RAM Replacement: passo 3, immagine 2 di 3 Lenovo B575-1450 RAM Replacement: passo 3, immagine 3 di 3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 RAM Replacement, Back Panel: passo 4, immagine 1 di 2 Lenovo B575-1450 RAM Replacement, Back Panel: passo 4, immagine 2 di 2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 RAM Replacement: passo 5, immagine 1 di 1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 RAM Replacement: passo 6, immagine 1 di 1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 RAM Replacement, RAM: passo 7, immagine 1 di 2 Lenovo B575-1450 RAM Replacement, RAM: passo 7, immagine 2 di 2
    • Using a plastic opening tool, pry the RAM upwards until the card pops out of the brackets.
    • Pull the RAM out from the slot.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,321
