Salta al contenuto principale
Lenovo A8-50 Motherboard and Speaker Replacement
Cosa ti serve
  1. Lenovo A8-50 Motherboard and Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover by prying it open with the metal spudger tool.
  2. Lenovo A8-50 Motherboard and Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the two screws with a PH000 head screwdriver.
    • Keep all your screws in one place.
  3. Lenovo A8-50 Motherboard and Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the metal piece.
    • Keep this piece safe, as you will need it to reassemble the device again.
  4. Lenovo A8-50 Motherboard and Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the battery by lifting it up using a plastic spudger.
  5. Lenovo A8-50 Motherboard and Speaker Replacement: passo 5, immagine 1 di 1
    • Disconnect the cable from the connection.
    • Be careful not to tear or bend the cable.
  6. Lenovo A8-50 Motherboard and Speaker Replacement, Motherboard and Speaker: passo 6, immagine 1 di 1
    • Unscrew the 5 black screws, and the 9 silver screws with a PH000 head screwdriver.
    • Set aside carefully.
  7. Lenovo A8-50 Motherboard and Speaker Replacement: passo 7, immagine 1 di 2 Lenovo A8-50 Motherboard and Speaker Replacement: passo 7, immagine 2 di 2
    • Remove the two black panels and the clear circle piece.
  8. Lenovo A8-50 Motherboard and Speaker Replacement: passo 8, immagine 1 di 1
    • Lift up the motherboard carefully, ensuring that you lift the speaker housing and the motherboard together
  9. Lenovo A8-50 Motherboard and Speaker Replacement: passo 9, immagine 1 di 1
    • Lift the bottom speaker piece up carefully
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,279
