Introduzione
If you forgot your password, screen lock or you have a problem with the Android OS or you want to erase all information from your table, you can do this with a Factory, Hard reset.
You can do this from Android System Recovery menu or from Factory mode menu.
Cosa ti serve
Panoramica Video
1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
2. Press and hod: Volume Up + Volume Down + Power buttons.
3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
1. Switch off the tablet.
2. Press and hold the Volume Up and Power On keys.
3. When you feel release only the Power button. Now your device is in Factory mode.
4. Use the Volume Up/Down keys for movement and the Power key for select.
5. Select ¶§ eMMC (Clean eMMC)
Did you do it successfully?
Altre 33 persone hanno completato questa guida.
17 Commenti
let me try and see
yes it works thanks
Love you so much goodnight baby
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
