Salta al contenuto principale
Lenovo A7-40, A7-50 A3500 Factory Reset
Cosa ti serve
Panoramica Video
  1. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: passo 1, immagine 1 di 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: passo 1, immagine 2 di 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: passo 1, immagine 3 di 3
    • 1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
    • 2. Press and hod: Volume Up + Volume Down + Power buttons.
    • 3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
    • 4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
  2. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: passo 2, immagine 1 di 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: passo 2, immagine 2 di 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: passo 2, immagine 3 di 3
    • 1. Switch off the tablet.
    • 2. Press and hold the Volume Up and Power On keys.
    • 3. When you feel release only the Power button. Now your device is in Factory mode.
    • 4. Use the Volume Up/Down keys for movement and the Power key for select.
    • 5. Select ¶§ eMMC (Clean eMMC)
    • Did you do it successfully?
Conclusione
Altre 33 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.278 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
17 Commenti
let me try and see
usman aleeyu - Replica
Is it applicable to my lenovo a516?
valvinzon - Replica
yes it works thanks
abdullahjanajy - Replica
Love you so much goodnight baby
Van Prince -
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
Christian Lemuel Espenilla - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 121
Tutti i Tempi: 106,136
