Salta al contenuto principale
Lenovo 300e Chromebook USB and Charging Ports Replacement
Cosa ti serve
  1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: passo 1, immagine 1 di 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: passo 1, immagine 2 di 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 2, immagine 1 di 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 2, immagine 2 di 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 2, immagine 3 di 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: passo 3, immagine 1 di 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: passo 3, immagine 2 di 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: passo 3, immagine 3 di 3
    • Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 4, immagine 1 di 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 4, immagine 2 di 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: passo 4, immagine 3 di 3
    • Detach the white and blue ribbon cable from its cable connector on the USB board.
    • Remove the USB board from the laptop.
Conclusione
Un commento
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
Juan Raul Hernandez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 41
Tutti i Tempi: 1,509
