Salta al contenuto principale
Lenovo 300e Chromebook Left and Right Click Buttons Replacement
Cosa ti serve
  1. Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Back Cover: passo 1, immagine 1 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Back Cover: passo 1, immagine 2 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 2, immagine 1 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 2, immagine 2 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 2, immagine 3 di 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Battery: passo 3, immagine 1 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Battery: passo 3, immagine 2 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Battery: passo 3, immagine 3 di 3
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 4, immagine 1 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 4, immagine 2 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 4, immagine 3 di 3
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
  5. Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Left and Right Click Buttons: passo 5, immagine 1 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Left and Right Click Buttons: passo 5, immagine 2 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement, Left and Right Click Buttons: passo 5, immagine 3 di 3
    • Disconnect the metallic electrical tape by gently pulling back away from the keypad.
  6. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 6, immagine 1 di 2 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 6, immagine 2 di 2
    • Remove two 5 mm screws from the metal plate using a Phillips #2 screwdriver.
  7. Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 7, immagine 1 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 7, immagine 2 di 3 Lenovo 300e Chromebook Left and Right Click Buttons Replacement: passo 7, immagine 3 di 3
    • Remove the left and right click buttons from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 280
