Salta al contenuto principale
Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal
  1. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove Backplate: passo 1, immagine 1 di 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove Backplate: passo 1, immagine 2 di 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove Backplate: passo 1, immagine 3 di 3
    • Turn off your computer.
    • Flip the Chromebook over and unscrew the screws securing the backplate.
  2. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing Screws from under laptop: passo 2, immagine 1 di 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing Screws from under laptop: passo 2, immagine 2 di 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing Screws from under laptop: passo 2, immagine 3 di 3
    • Unplug the Battery
    • Unscrew battery and remove
    • Remove all all circled screws
    • I removed the wireless card. I don't know if it's required.
  3. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the Keyboard: passo 3, immagine 1 di 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the Keyboard: passo 3, immagine 2 di 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the Keyboard: passo 3, immagine 3 di 3
    • Slide Keyboard up
    • Wedge something under the keyboard
    • flip the keyboard over
    • carefully remove the keyboard ribbon cable
  4. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing the Bezel: passo 4, immagine 1 di 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing the Bezel: passo 4, immagine 2 di 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing the Bezel: passo 4, immagine 3 di 3
    • Unscrew and disconnect ribbon cables
    • wedge something between the bezel and slide across the edge until the bezel is lifted (like taking off a bike tire)
  5. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the write-protect screw: passo 5, immagine 1 di 2 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the write-protect screw: passo 5, immagine 2 di 2
    • The write-protect screw is clearly conducting electricity (compare it to other screws on the board).
    • Leave the WP screw out of the laptop.
Conclusione
Altre 4 persone hanno completato questa guida.
Dean Gadberry
Membro da: 02/27/21
424 Reputazione
2 Guide realizzate
4Commenti sulla guida
Le système software this chromebook
boubker bouchagra - Replica
This chromebook runs ChromeOS. Removing the write-protect screw and running MrChromeBox's Firmware Utility Script allows any linux distribution to run on this chromebook.
Dean Gadberry -
Bravo, merci bcq pour ça
Christian Fela - Replica
Je suis content que cela ait aidé !
Dean Gadberry -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 288
Tutti i Tempi: 7,474
