Salta al contenuto principale
Lenovo 100s Chromebook-11IBY Screen Replacement
Cosa ti serve
  1. Lenovo 100s Chromebook-11IBY Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 3, immagine 1 di 2 Lenovo 100s Chromebook-11IBY Screen Replacement: passo 3, immagine 2 di 2
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 4, immagine 1 di 1
    • Use the opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 5, immagine 1 di 2 Lenovo 100s Chromebook-11IBY Screen Replacement: passo 5, immagine 2 di 2
    • Use the #0 Phillips screwdriver to remove the four 6mm screws from the screen.
  6. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 6, immagine 1 di 1
    • Gently remove the screen from the plate and place it on the keyboard.
    • Be careful not to pull screen the immediately or completely out because cables are attached.
  7. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 7, immagine 1 di 1
    • Gently remove the adhesive tape from the back of the screen.
  8. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 8, immagine 1 di 1
    • Unplug the screen from the laptop.
  9. Lenovo 100s Chromebook-11IBY Screen Replacement: passo 9, immagine 1 di 2 Lenovo 100s Chromebook-11IBY Screen Replacement: passo 9, immagine 2 di 2
    • The screen may now be removed completely from the laptop.
    • The back side of the screen has the screen's model number and manufacturer.
Conclusione
USF Tampa, Team S7-G2, Cagle Spring 2017 Membro di USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Membro
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,869
