Salta al contenuto principale
Lenovo 100e Chromebook 2nd Gen Trackpad Replacement
Cosa ti serve
  1. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 2, immagine 1 di 2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 2, immagine 2 di 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 3, immagine 1 di 2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 3, immagine 2 di 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Trackpad: passo 4, immagine 1 di 1
    • Remove the three 2 mm Phillips #00 screws holding the trackpad in.
  5. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 5, immagine 1 di 2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: passo 5, immagine 2 di 2
    • Push up on the side of the trackpad that faces the screen.
    • Pop the trackpad out and remove it from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 41
Tutti i Tempi: 1,044
