Salta al contenuto principale
Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement
Cosa ti serve
  1. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: passo 2, immagine 1 di 2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: passo 2, immagine 2 di 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: passo 3, immagine 1 di 2 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: passo 3, immagine 2 di 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Headphone Jack: passo 4, immagine 1 di 1
    • Remove the three 4 mm Phillips #0 screws holding the headphone jack in place.
  5. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: passo 5, immagine 1 di 1
    • Using a plastic opening pick, remove the connection between the aux port and the speakers.
  6. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: passo 6, immagine 1 di 1
    • Using the plastic opening pick, pop the retaining flap holding the ribbon cable in place.
    • Remove the headphone jack from the laptop.
Conclusione
Un commento
I believe our model has the headphone jack soldered on. Any other ideas?
L Hart - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 946
