Salta al contenuto principale
Lego Dimensions Starter Pack USB Cable Replacement
Cosa ti serve
  1. Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: passo 1, immagine 1 di 2 Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: passo 1, immagine 2 di 2
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack USB Cable Replacement: passo 2, immagine 1 di 1
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack USB Cable Replacement: passo 3, immagine 1 di 1
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack USB Cable Replacement: passo 4, immagine 1 di 1
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack USB Cable Replacement: passo 5, immagine 1 di 1
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack USB Cable Replacement, USB Cable: passo 6, immagine 1 di 1
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
Conclusione
Altre 3 persone hanno completato questa guida.
Alyssa Lach
Membro da: 11/06/17
509 Reputazione
4 Guide realizzate
IUPUI, Team S5-G2, Baechle Fall 2017 Membro di IUPUI, Team S5-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G2
2 Membri
8 Guide realizzate
2 Commenti
Where do you buy the USB cable from?
jaimea371 - Replica
mguzmanv - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 5,328
