Salta al contenuto principale
Leapfrog My Own Leaptop Battery Replacement Guide
Cosa ti serve
  1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: passo 1, immagine 1 di 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Battery Replacement Guide: passo 2, immagine 1 di 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Battery Replacement Guide: passo 3, immagine 1 di 2 Leapfrog My Own Leaptop Battery Replacement Guide: passo 3, immagine 2 di 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
Linea Traguardo
USF Tampa, Team 14-6, Lacy Spring 2016 Membro di USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 Membri
6 Guide realizzate
Un commento
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 66
Tutti i Tempi: 2,977
